-   -   Bolting / Sinking screw into a nida-core panel (http://www.classicseacraft.com/community/showthread.php?t=14660)
Bigshrimpin 08-29-2004 11:44 AM
This page shows how to reinforce a nidacore panel so that it can take screws/bolts . . . basically says to fill the area that will be receiving bolts with a polyester or epoxy putty before you laminate the side. Looks promising!!
http://www.protechmarinecenter.com/n...e/Repairs.html
warthog5 08-29-2004 03:01 PM
Re: Bolting / Sinking screw into a nida-core panel
Here's another webpage on that subject.
http://bertram31.com/proj/tips/sleeving.htm
I used both methods. In the transom I used PVC tubes where heave stuff will be mounted.
Where small pieces like wiring will go thru I filled it with epoxy putty.
