-   -   Please opionions on best COMPOSITES for stringers (http://www.classicseacraft.com/community/showthread.php?t=18630)
3rdday 01-03-2008 11:43 AM
Please opionions on best COMPOSITES for stringers.
Foam Filled with 2 part USCG?? Coosa,Nidabond,nidacore,Divinycell,Seacast??????? Or build up existing with layers of glass and no core. Want to avoid, rot, waterlog, etc..Much thanks in advance.
gofastsandman 01-03-2008 09:23 PM
Re: Please opionions on best COMPOSITES for strin
Hey 3rd,
Goin to see George at G&S Fri about a similar problem and I`ll ask him.
GFS
3rdday 01-03-2008 10:07 PM
Great, I really appreciate the willingness to help. If you don't mind ask him what the opinion on cutting the caps off the stringers and gutting then filling with pourable or rigid foam like divinicell or using a pourable composite like seacast or Nida bond(transom filler)Then re-capping the Stringers.
Thank you.
htillman 01-03-2008 10:40 PM
It will be interesting to find out the opinion from G&S. But from what I have read on this website, cut the tops off, remove old foam, install new foam (2 part) and then reinstall the tops. Refer to Stricks string if I remember correctly. The USCG has a requirement for foam. I would not put Seacast or a hardened product in the stingers. Weight of these products may become a facter. I drilled holes in the bottom and top of my stingers and let them dry. I will reseal them when I seal the top hatch.
Islandtrader 01-04-2008 10:08 AM
This is something I just read...and since I am new at the restore stuff I will be interested in knowing what folks think.
The article stated that you should stay with like material, if you are only replacing sections of stringers etc. wood stay with wood, foam, stay with foam.
I know some of the 21's stringers glass has pulled away from the stringer, now looking for the right and easiest way to fix.
3rdday 01-04-2008 10:52 AM
Terry,
Where did glass pull away? Where the stringers are tabbed to the hull?
3rdday 01-04-2008 07:20 PM
I saw some past posts from Don (Hermco). looks like leaving them hollow or placing 4lb rigid foam inside stringer cavities may be the way to go. Regardless, I will probably abbrade the stringers and add extra layers of Glass (build them up)
gofastsandman 01-04-2008 07:45 PM
Saw George this am and I`m sorry , but he forgot my hub I had ordered and I forgot to ask.Maybe he`ll be at the shop in the am. Once again I feel stupid. I will get an answer.
GFS
3rdday 01-04-2008 08:51 PM
No worries .
Islandtrader 01-05-2008 10:12 AM
Stringer
http://i266.photobucket.com/albums/i...r/IMG_3054.jpg
Let see if I can explain this. If you take the stringer and pinch it. It will compress. If you try torquing it left and right it will give? twist slightly. Now this does not happen through out the stringer just in certain spots. You can see the stringer glass has not pulled away from the hull. Just that the interior bond to the wood is gone (or the wood is gone). Hope this makes sense.
That is why I am wondering if a pour composite might work?
