-   Recovered Threads (http://www.classicseacraft.com/community/forumdisplay.php?f=13)
-   -   Trailer Help needed - Bearings (http://www.classicseacraft.com/community/showthread.php?t=26901)
77SceptreOB 11-28-2014 07:26 PM
Well the last scheduled trip of the year started off well.
http://i233.photobucket.com/albums/e...ps36f6aef7.jpg
Great time on the water! :)
http://i233.photobucket.com/albums/e...ps69d88abb.jpg
Then on the way back I blew out a bearing...:(
http://i233.photobucket.com/albums/e...pse91ecf69.jpg
http://i233.photobucket.com/albums/e...ps0f299aa4.jpg
So I hiked the axle up and secured it and successfully limped on home... and so the "repairs" start
http://i233.photobucket.com/albums/e...pscc2f19ba.jpg
Here are some pictures of the axle spindle after I got the hub assembly off.
http://i233.photobucket.com/albums/e...ps439a4582.jpg
http://i233.photobucket.com/albums/e...psb74398f4.jpg
The spindle has some scratches and small gouges in it, but nothing too severe.
So, can I just buy some new bearings and put the hub back on this spindle?
gofastsandman 11-28-2014 09:31 PM
Yikes. Is that an unintentional welded ridge?
Old'sCool 11-28-2014 10:23 PM
What size bearings? I have 4 new sets looking for a home...complete w/seals.
77SceptreOB 11-28-2014 11:49 PM
Not sure yet, but I'll keep you in mind! Thanks.
77SceptreOB 11-28-2014 11:52 PM
After closer inspection, it appears the larger inner bearing and race seem to be intact.
BUT, the outer bearing and race are a different story. the outer race is chipped, gouged, and cracked. The outer bearing is in hundreds of little pieces, totally discentigrated.
http://i233.photobucket.com/albums/e...psc5cfb198.jpg
Ed 11-29-2014 09:40 AM
You may want to get yourself some speedy sleeves. They will provide the new bearings a smooth surface to ride on.
Islandtrader 11-29-2014 09:51 AM
I don't know the cost factor...but my mind set is always get rid the old part and start new. In the long run (for me) I have found this to be the cheapest way out.
cdavisdb 11-29-2014 09:56 AM
I'm with Island Trader. You might get away with a fix, but that looks to me like trouble down the road. The ugly question is "Can you change spindles without changing the axle?"
FishStretcher 11-29-2014 10:40 AM
I'd say you need a new axle. I doubt replacing a stub axle would be cost effective, if you could do it. Looks like some wear on the seal area which might have contributed?
Entire axles are heavy but not that hard to do- you are a third of the way to disassembly anyway.
Good luck. I hate trailer trouble.
DonV 11-29-2014 10:44 AM
Jim a new axle with flanges is about $175, http://www.sturdybuiltonline.com/Tra...c_146-1-1.html , your spindle looks good enough to save. Your SS inner seal ring looks perfect. Had the same thing happen to me on Alligator Alley and the hub wore down the outside bearing's mounting surface about 1/16". Took some emory cloth and worked on the outside bearing surface until the inner race would slide on smoothly, put on a new hub, with new bearings and used it for another five years.
To answer Conner's question, yes it can, I've done it, however I can't remember if it was on an axle with a brake flange! The weld can be cut with a metal cut off wheel, the old spindle removed and a new spindle slid back in and welded in place. However the welding will burn off about 1" to 2" of galvanizing on the axle and we know what will happen in the saltwater world the trailer is dunked in.
