-   Recovered Threads (http://www.classicseacraft.com/community/forumdisplay.php?f=13)
-   -   Core thickness for hatches and deck on 1988 23CC (http://www.classicseacraft.com/community/showthread.php?t=29869)
Benzzino 04-21-2019 05:07 PM
Does anyone know the core thickness on the hatches and the deck on a 1988 23 CC? I have one side of the aft deck soft that needs to be replaced, the live well hatch is bowed down, the small hatch over the fuel tank as well as the large hatch over the fuel tank and under the console. Also, if anyone has any experience with cutting the core out of the bottom of the hatches I would appreciate any advice.
Kraken 04-21-2019 05:56 PM
Deck is 3/4 plywood. Use an oscillating metal blade to access the core.
KNZ911 04-21-2019 06:58 PM
Look deeper than just the hatches! I see a complete resto in your future.
mikeyk 04-22-2019 12:39 PM
While servicing my fuel sending unit I realized that the hatch, while not spongy, had experienced water intrusion probably due to unrepaired screw holes by previous owner(s). The hatch weighed over 80lbs!
I took a circular Skilsaw with a carbide blade and cut out the waterlogged plywood core, leaving a 2" wide frame. After letting it dry, I cut out and inserted a panel of 3/4" Airex foam, glassed both sides and gel-coated and non-skidded the deck side.
Benzzino 04-22-2019 08:34 PM
Thanks for the responses. So do you think I should use marine ply or Coosa board? For these hatches. I was planning on replacing the deck in a few years.
Oldboat 04-23-2019 08:28 AM
I put 2 ribs on my rear hatch were all my 250 lb friends will be standing bottom fishing for hours drinking beer
