Thread: Need a cover
Old 04-25-2002, 12:30 PM
Trayder Trayder is offline
Velvet Jones
Default Re: Need a cover
BillyBob-
I had the same problen with my other boat. I could not find a cover that was off the shelf that even came close to fitting. @ 28LOA and a T-top I was up a creek with out a paddle so to say.
I priced Sunbrella covers and almost lost it good grief!!!. I wound up having a local guy make one out of some sort of Hot air Balloon material. it was much less expensive per yard then sunbrella yet much lighter and stronger. It is white and drapes over the console around the t-top and then out over the decks. I had him install straps and buckles to go around the trailer which makes it tight and then a long zipper from the rear of the console to the transom. I am thrilled with it and it was only a couple of hundred dollars more than the Covers I have seen advertised in the catalogs which would have ended up costing the same after they were refitted to work.
I told him to keep the templates in case someone else was interested. I would still think he would want you boat @ his shop to fit it and he is in Portsmouth RI. He had my boat for 2 weeks. It was $710.00 for a 28LOA boat. If this is of interest to you I can e-mail you some Pics and his #
