Re: Questions about a 1987 23' CC
ED, I have a 1986 and my transom height is 30.5".
I believe yours will be the same. I think the older SeaCrafts have a 25" height. If you check my post you will see the problem I have with twins and my shafts are 25". A single engine would need a 30" shaft on a 30" transom, but with twins you move them out so I was told because of the v hull 25" shaft are used. Also under 150 hp the only shaft lenght is 20 or 25". I can tell you this if you have a 30" transom you take very little water over the transom.
