Old 05-03-2002, 03:26 PM
Scott Scott is offline
Default Re: Questions about a 1987 23' CC
Hi Ed
Your in the ball park of when Tracker took things over. As far as what year hull to buy...I personally dont think there's alot of difference...bottom line it has the same shape but I dont know if they got light in laying up the glass on the boat (that would be something to check on)..The biggest issue you may run into...as mentioned before in a post...is the quality of the hardware might not be up to par...That being said chances are that in buying an older boat you would most likely replace the hardware anyway....I know that when my boat is done what will be left original is the hull the decks the hull cap and the console....everything else needed to be or will be replaced due to age concerns and corrosion. I wouldnt worry too much…. just look it over well…. maybe even get it surveyed if your not super comfortable with going through the boat...
When I bought mine I basically bought the hull...thats all that I wanted.
Thanks Trayder ... thats the post [img]images/icons/smile.gif[/img]
[ May 03, 2002, 02:31 PM: Message edited by: Scott ]
