Old 12-18-2003, 07:59 AM
PipeDreamsMarine PipeDreamsMarine is offline
Default Re: Bow Heavy Sea Craft
This is kind of a "redneck" fix for your problem.. but you hate when you wash the boat down and the water runs forward.. . and if you sit on the motor it runs out and your 170 pounds.... Well 170lbs is 85 quarts..I had a boat with the same problem and what I did was to fill my 96 quart bait cooler with water after I washed the boat down.. added some soap and bleach and let it sit till I use the boat again. I put a 18" piece of hose over the drain and moved the plug to the end of the hose. When I used the boat I just pulled the plug and it drained out the scupper and I had a nice clean and good smell'in cooler and a boat that sat nice..
[ December 18, 2003, 07:00 AM: Message edited by: PipeDreamsMarine ]
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
