Old 08-23-2002, 05:03 PM
Default Re: To bracket or not to bracket?
HA BRIGUY
WHEN I DID MY TRANSOM I REMOVED THE BAIT WELL. WHAT YOU HAVE THERE IS THIS. ON THE BOTTOM OF THE LIVE WELL HAS A SOLID GLOB OF FIBERGLASS RESIN ABOUT THE DEMETER OF A MEDIUM DINNER PLATE AND ABOUT I/2 TO ¾ “ THICK THE LIVE WELL SITS ON THIS GLOB AND THE THROUGH HULL FITTING IS DRILLED DIRECTLY THROUGH THE LIVE WELL, THE GLOB AND THEN THROUGH THE HULL IT IS ALL WATER TIGHT SO YOU DON’T HAVE ANY WATER SEEPAGE. THEN ON THE BACK OF THE LIVE WELL DIRECTLY IN FRONT OF THE TRANSOM IS A SMALL SPACE, THE LIVE WELL IS NOT CONNECTED TO THE TRANSOM. SO IF YOU ARE THINKING OF DRILLING HOLES THROUGH THE LIVE WELL TO MOUNT THE BRACKET YOU GOT WATER SEEPAGE PROBLEMS.
FELLOW-SHIP [img]images/icons/shocked.gif[/img]
