Old 10-11-2002, 10:04 AM
Default Re: Bottom paint removal
HA JACK
I HAD MY 23 SODA BLASTER WITH TECHNIQUE CALLED ENVIRO STRIP YOU CAN READ ABOUT AT http://www.jacksonmarine.com/ THEY DID MY BOAT FOR $600.00 AND IT WAS WELL WORTH IF FOR ME. I KNOW YOU CAN RENT THE EQUIPMENT & DO IT YOUR SELF IF YOU HAVE A PLACE THAT YOU CAN DO THIS TYPE OF WORK. IT WILL RUIN THE GROUND UNDER THE BOAT. THIS IS NOT A DRIVEWAY TYPE JOB. THE SODA BLASTING METHOD IS A LOT EASIER OF THE HULL I DID GET SOME PITTING OF THE GEL COAT BUT DID NOT GET INTO THE FIBERGLASS. I THEN HAD THE ENTIRE BOTTOM RE GEL COATED. THAT WAS ANOTHER $600. I STILL HAVE TO SAND IT SMOOTHER AND PROBABLY RE GEL COAT ANY SPOTS THAT GET TOO MUCH SANDING. THEN RUBBING COMPOUND AND WAX.
FELLOW-SHIP [img]images/icons/cool.gif[/img]
