Old 12-31-2002, 07:14 PM
John R John R is offline
Default Re: FINALY!!!!!!!!!!!!!!!!
Scott - that thread was a pain. It was too much to bear and I was guilty of feeding that fire... Are you registered over there under a different name?
I can't complain about that Ford. It was the best truck I've ever owned and only had 3 problems. A coin got stuck in the console lock and jambed it -not Ford's fault, the pass side door sill moulding would never stay on, and the scary one: the throttle cable froze northbound on the Expressway in Dot at 75 mph & 3500 rpm. I had to quick shift down the offramp to get it off the highway. Turned out condensation had built up around the linkage and froze under my high speed run down the X-way. Also probably not Ford's fault.
Right now the rebates from GM are great too - 3K.
I just have problems buying a vehicle in it's 1st or last year of a particular generation. So I'm up in the air too.
Later,
John
Surf and Boat fishing for
Striped Bass
