Thread: 225 Evinrude
Old 10-07-2002, 10:54 PM
Briguy Briguy is offline
Default Re: 225 Evinrude
Sounds powerfull. My twin 4 stroke suzuki's run about a knot and a half faster at both rpm's. If you cut a tight corner at 4k rpm's the motor should blow out just a little, if not, you might want to go up a hole. Are you running a 15x17 or a 14 1/4x19? (Those are the two props I ran when I had a single 225.) How much more $$ was the 250?
Capt. Brian
