Re: Ficht 200 vs Hpdi 200
The Evinrude weights 532 lbs. Has a dual Voltage 60 amp alternator. comes with a non declining warry. Yamaha weights 570 lbs. has a 50 amp charging. and has a declining warry.
The Evinrude also has which Yamaha does not 304 s.s. steering arm, closed deck cylinder block, plus a relieved split line gearcase. Evinrude also has Adjustable Cooling water tell-tail, trim limit switch, built in trailer support arm. Yamaha comes with non of these items listed. Plus Evinrude parts are much easier to get then Yamaha parts. At least it is in my area. I would think your local dealer should stock these engines. IF not as long as its ordered by April 15th you will still get the rebate or extra warry.
