Old 05-04-2003, 04:39 PM
hermco hermco is offline
Default Re: SeaMark Outboard bracket Photos
The pic of the boat with the single 30"motor is a twin bracket with a single 30" shaft length motor that can accept the install of two 25" motors in the future.The beauty of using the twin bracket with a single 30" shaft motor is you get approx 850 lbs. of floatation from the twin bracket that only has to "float" 500 lbs. of motor (250 hp).You are offsetting the weight of the motor and gaining buoyancy in the stern.The fact that the bracket is all fiberglas means you are actually "adding boat" not bracket. and getting all the benefits of a bracket mounted engine.
d.h. [img]images/icons/grin.gif[/img]
