Old 12-09-2003, 07:09 PM
barnacle barnacle is offline
Default Re: Cavitation plate
Years ago it was even with the bottom. Today everything is mounted from even to 1" above the bottom. The higher you get it the faster it will go. Rember to keep the water intakes below water level while running at high speeds. The only problem with it being up 1" is that it big seas it may not stayed hooked up. You need to know what your rpms are before you start anything.
