Old 12-17-2003, 03:03 PM
Dave Hirshberg Dave Hirshberg is offline
Default Re: Fuel Tank Support
Abl,
You did it perfect. With epoxy and Awlgrip your tank is virtually impervious to corrosion on the outside. It is the absolute best way to do it. If you don't have tabs on the tank sides you can foam it in with cross members over the top to keep it from lifting in the foaming process. Make sure to lay down strips of 1/4 inch starboard or hard rubber strips under the tank to allow drainage.
