Old 01-06-2004, 01:43 AM
sebaugh sebaugh is offline
Default Re: Inboard hydraulic steering setup
I replaced my steering (20' CC) with a Hynautics system. I belive it is undersized and does not perform as well as it should. That being said, the biggest thing I overlooked was the tubing setup. Instead of having a fixed piston and 2 fixed lines to it, the piston moves side to side as the wheel is turned. Each end has a line going into it which means I need extra tubing to allow for play (similar to the control cables). I would make sure whatever setup you go with that is ample sized for the motor and that the piston stays in a fixed position allowing for fixed length tubing.
