Re: Scuppers
Hello,Scott I recently closed up the floor scuppers and went thru the transom and it works fantastic.We put in these cone scuppers that dont let a drop of water in.Blackwater ,I finally got rid of the well,closed in the transom and had a Livewell built in it,its fantastic.I went with an Armstrong wide body bracket it is great.When the boat sits in the water the bottom of the scuppers lay even with the water line,the bracket has a chamber in it which makes the boat float higher at the stern,I acually raise the stern 1 and a half inches.Dont waste you $$$ on raising the deck,you dont need it.
