Re: Help with steering problems
John B
It takes time to get rid of all the air in the lines. Take the little filler cap off and put a rag around the steering collum . turn the wheel back and forth . do this till your blue in the face. make sure you keep the fluid almost to the top. but be carefull not to get your nose to close. when an air pocket hit's the top it will bubble up and the juice will run out. replace what you lose.keep the fluid almost to top. It need's to be full to work right.-----steve.
