Old 04-17-2002, 04:10 PM
hermco hermco is offline
Default Re: Plywood core in hatches
Scott,
I don't know the original thickness but it probably would not apply with todays measurements.Use what will work the best for the job at hand.I would use AC ply and the drilled hole trick will work fine as long as you weight the wood down good.Using a notched trowel to apply the putty will help also.
