Thread: Transom Height
Old 06-05-2002, 01:25 AM
TonyS TonyS is offline
Default Re: Transom Height
My 1986 23' has a 30" transom, and I believe the 1980 boats and up have 30" transom. check out the new boats, they use 30" shaft motors. The problem I have is with twin engines, because they need 25" shafts, that I have but, they are not spaced right so they are too high on the transom causing blow out. This I can tell you the splash well has very little water over it. Good Luck
