Old 06-08-2002, 01:31 AM
Scott Scott is offline
Default Re: Vent on scepter, water in gas
Hey John
All I can say is that on mine the vent is about six inches under the rub rail and is angled back so even if water were to run up the side of the hull it would deflect from the vent .... unless somehow there was a vacuum in the tank.
If yours is pointing straight down maybe its scooping up water as its forced past the vent... Just a thought. It should be easy enough to angle the vent to the aft of the boat.
You sure your not getting water in the courtesy of your fuel dock/gas station?? [img]images/icons/confused.gif[/img]
Hope you get resolve to the problem quickly !!!!!
[img]images/icons/smile.gif[/img]
