Thru hull scuppers ... How did ya fix em
The thru hull scuppers in the 23……. How did you guys fix them???
One of mine is corroded and eaten away .... and I'm thinking its mounted through wood (Fellow-ship did you say they were in a block of wood??)
Any easy, curse free methods for removal of the old brass tubes and replacement with...I guess the same??? Unfortunately the top half of the tube (closest to the deck) is in there pretty good....but the bottom half is just about gone. Where do you find the replacement tubes and what’s the best way to get them back in there....I think I was told at one point Whaler has them long enough to reach the deck from outside the hull???
At this time I want to replace as originally designed.....In the future that may change ….but until the transom is addressed .. one way or another ....I'll most likely leave them thru the deck.
Thanks
Scott
