Re: Bow mounted trolling motor
I installed mine using a Minn Kota quick release mount I found in Cabelas. It is two pieces. The flat aluminum base is mounted on the bow with four bolts. The other part mounts directly to the trolling motor (it could tapped and drilled to fit any motor)with four bolts. To install or remove it you just slide the motor onto the base and put a quick release pin in to keep it together. I fish offshore and this was the cleanest install I could find that allows me to remove it quickly.
Mine motor is a 36Lb thrust 12 volt Minn Kota. It pulls the boat great unless wind or current are really riping.
