Re: Using a Molding Table
Scott M-
I made the rod racks using 2x4s and 2 inch PVC. I put two sections of 2x4's on the bottom and then a row of 2 inch sections of PVC up top. The butt of the rod goes throgh a hole drilled in the first 2x4 and then stops against the second 2x4 while the rod section is fit in a slot cut into the side of the PVC and then gravity does the rest.
