Old 12-31-2002, 03:52 PM
jw jw is offline
Default Re: painting fiberglass
RS,
You can shoot Grip, the primer is easier to shoot than the topcoat. The trick I have learn is that it takes time as you spray on light misting coats, waiting 15min in between coats. and keep on doing this. If you get ansty, it will look great till you walk away to clean your gun, and come back and see runs and sags everywhere.
Sure, it is nasty paint, I wear a full face 3 M resperator and tyvek suit and rubber gloves . I also have a big shop and cross ventalation. I can be done by a non pro, just spend some money on your respirater even if you should roll and tip the paint, which looks just as good
REMEMBER LOTS OF LIGHT COATS, WATING IN BETWEEN COATS.
gOOD LUCK.
JW
www.bansheecharters.com
Wishn' I was Fishn"!!!!
