Old 01-01-2003, 08:45 PM
ltdan ltdan is offline
Default Re: Gas Tank removal
I NEED SOME OPINION'S/HELP. LT DAN HERE,I JUST GOT STARTED ON A 23C.C. REDO, AND I WANT TO PULL THE TANK. WITH THE CENTER FLOOR PIECE OUT,FROM WHAT I CAN SEE THE TANK LOOK'S GREAT. IT'S BEEN COATED WITH GREEN EPOXY. LOOKING THROUGH THE SENDING UNIT HOLE,FROM WHAT I CAN SEE, THE TANK LOOK'S NEW!! NO DIRT NO SLUDGE OR GEL. THE HULL'S AN 83" AND MY GUESS IS THE TANK'S ORIGINAL.(CANT READ THE ID BADGE) NO FUEL SMELL AND NOTHING VISUALLY TO INDICATE A PROBLEM. TO GET TO THE FOAM ON THE SIDE'S WOULD MEAN CUTTING THE EDGE OFF ALL THE WAY AROUND THE OPENING THAT THE DECK PIECE SIT'S ON AND SCREW'S TO. ANYBODY GOT SOME IDEA'S? SHOULD I LEAVE WELL ENOUGH ALONE? I'LD GO NUT'S IF I HACKED UP SOME OF THE DECK JUST TO FIND OUT THE TANK'S O.K. [img]images/icons/mad.gif[/img] THANK'S IN ADVANCE LT DAN
