Re: Paint Job
Hi Merriweather- Bill Sirotnak here, the color on mine is called fighting lady yellow and when I bought the hull, the yellow had already been done recently with Awlgrip or Imron, I just had to do the bottom and the cockpit/topsides.As for the type of paint, on the outside I would use a 2-part.Imron,Awlgrip,Sterling,Interthane are all good.If you're going to do it yourself,many people have rolled and tipped with good results.If you spray this stuff, you need an air supplied respirator as it is VERY toxic.For the cockpit/topsides I used Easypoxy only because I wanted to spray it and I was doing it in the driveway and didn't want to take a chance.But the Easypoxy has held up well.Hope this helps, congrats on your new ride!
