Old 02-06-2003, 01:11 AM
Trayder Trayder is offline
Velvet Jones
Default Re: Paint Vs. Gel-coat
Hello guys- I wrote this on another board a while back:
I have re-gelcoated 3 boats and will be doing a 4th this spring, my 20 ftr. I will share with you what has worked for me.
Depending one where you purchase your Gel-Coat, it is NOT more expensive than Awl-Grip or Imron. The last boat I did, A Mako 19, a Gel Coat jobwas 1/8 the price of an Awl-Grip job (doing it myself)
Granted we used plain white gel-coat.
The prep work was easy.
1. Sand to original gel-coat (if previously painted), fill cracks dings etc with a polyester based filler or resin.(some say you can use Epoxy, just get rid of the ameine(SP??) blush.
2. Sand entire hull with 80 grit sand paper. Make sure you keep the sander flat against hull.
3. Wash hull with Acetone Tape boat. Trailer etc
4. Figure your working time with the gel-coat. Mix enough Acetone into the gel-coat so it will pass through your sprayer. I add the following way in a 2 quart mixing pail:
1: Add Gel-Coat
2: Add reqd' amt of MEKP
3: Thin with Acetone
4: Mix Thoroughly
Mix a small batch and time how long it takes to kick. REMEMBER this time. Temps Humidity, etc change things.
5. Mix a batch and begin spraying/rolling. Stop 1 min before the kick time and run to a waiting batch of ACETONE. Empty sprayer and douse everything with acetone, run acetone through sprayer assuring nothing will cure in sprayer.(VERY IMPORTANT)
6. While cleaning have someone mix another batch and begin spraying / rolling again.
7. Do this process until the boat is cover to 22mils of Gel. Took 3 coats on a Mako 19 using 1 gallon of gel coat.
Now the hard part:
The boat will now look terrible depending on your spraying skills, all orange peel, some runs etc. I am not a skilled sprayer so your skills may be better. Do not fret if it looks bad. The beautifying stage with gel-coat comes last. (for me at least)
1. For white/light color boats: rum Dye-Kem over the entire hull. Dye-Kem is a blue dye used when cutting sheet metals.
2. Begin sanding, making sure you keep the sander flat against the hull. Begin with a grit you feel comfortable with, do not cut too much. Some start with 120 other 100 and some 80 grit.
3. Stop and move to next section when the blue dye disappears. The blue dye shows the peaks and valleys so when it is all white you know to stop.
4. Switch grits up to desired finish, some 1000 others 1500 2000 etc.
5. Compound entire hull and wax.
Thinking about it,Gel coat is more expensive for a professional job as it is labor intensive. Material wise I have found it to be much less expensive.
1. Gal of Gel-coat w/ MEKP plus wax additive $50.00 From LBI Fiberglass
2. Acetone LOTS OF IT!!! $30-50
I am sure there are other ways of doing this process. This is the way that works for me. I have yet to roll gel-coat but plan on doing rolling the next boat.
Good Luck
