Old 02-25-2003, 09:13 PM
Jon G Jon G is offline
Default Re: Leaking floor scuppers
Welcome to CS RIRED. The best way to fix those scuppers is to replace the brass tubes with new ones and seal them real good. If you do a search here for "scuppers" I'm sure you will find a few posts about this problem. As for the water shooting in one of them check that they both have the small piece of glass that acts as a deflecter still there. These are a small rectangle wedge on the outside of the hull just in front of the scuppers. It sends the water down slightly before it goes over the end of the scupper. If you are missing one of these you might be catching some water or the bottom of the tube is damaged grabbing some water as well, take a good look at you tubes on the outside. You do not [img]images/icons/shocked.gif[/img] want these leaking into the bilge. [img]images/icons/smile.gif[/img]
