Old 03-27-2003, 05:27 PM
Default Re: Gel coat or AwlGrip
RICK YOU COULD PROBABLY GO WITH ONE GAL OF PRIMER AND ½ GAL OF THE PRIMER CATALYST AND THEN ONE GAL OF PAINT AND ½ GAL OF THE CATALYST YOU WILL ALSO NEED BRUSH THINNER AS WELL ON THE PAINT IT’S 2 PARTS PAINT ONE PART CATALYST AND ONE PART BRUSH THINNER. THE COMPANY REP. SAID IT’S BETTER TO BUY SMALLER SIZES OF THE CATALYST IF YOU ARE NOT GOING TO USE IT UP IN A SHORTER PERIOD OF TIME THAN ONE BIGGER CONTAINER ( 2 QUORTS INSTEAD OF ½ GAL SIZE). YOU SHOULD PRIMER FIRST SAND AND THEN AT LEAST 2 OR BETTER 3 LIGHT COATS OF PAINT REMEMBER TO SAND BETWEEN COATS. THE JOB WILL COME OUT LOOKING VERY GOOD. ON THE LAST COAT USE A VERY GOOD BRUSH. GOOD LUCK REMEMBER IF YOU DON’T LIKE THE QUALITY OF YOUR JOB YOU COULD ALWAYS HAVE A PRO SPRAY THE LAST COAT. THAT WILL NOT HAPPEN BUT IT WAS COMFORTING TO ME KNOWING THAT IF I SCREWED UP ALL I HAD TO DO IS SAND IT SMOOTH AND CALL IN A PRO FOR THE LAST COAT.
FELLOW-SHIP [img]images/icons/wink.gif[/img]
