Re: gunnells
Tango,
Have you removed your rub rail and checked how well the cap is connected? Is the flexing coming from the cap and the hull connection being lose, or is the fiberglass rotting?
The rub rail is connected with screws, but the cap to hull connection is made with aluminum rivots (which I found many of mine were barely there if not gone). This is an easy fix, but if it's the fiberglass issue, you may have a big job ahead of you.
Good Luck!
Lloyd
