Old 05-07-2003, 11:19 PM
Briguy Briguy is offline
Default Re: Splashed my bracket!
No photo's from the sea trial but this wekend I will have some. As for measurements, Dan, I better leave that up to Armstrong to explain. My measurements were different due to 26" centers and running duals. If you want me to go ahead and explain it anyhow, let me know. One other problem I ran into is I think my motors are mounted too high. I need to keep some pretty serious negative trim to get on plain and while running or the props will blow out. Even at WOT, my motors are barely level and begin to blow out the props. They are mounted on the 4th hole up so I have ample room to lower them down. I will probably run it a few more hours and then drop the motors a hole or two. Any thoughts?
Capt. Brian
