Thread: chainsaw!
Old 05-15-2003, 10:09 AM
Default Re: chainsaw!
HA MADA
LOOKS LIKE YOUR TRYING TO SAVE TIME BY DOING THIS JOB WITH THE CHAIN SAW IDEA. NOW THIS IN JUST MY OPINION BUT YES YOU PROBABLY COULD LEAVE 3 “ ALL AROUND AND CUT THE ENTIRE TRANSOM OFF. THAN REMOVE ALL WOOD LEFT BETWEEN THE TWO REMAINDER SKINS WITH A CHISEL THEN YOU COULD BUILD BACK THE OUTER SKIN WITH A SHEET OF ¼” OR THICKER GLASS PANEL THEN BUILD THAT UP BY ADDING MORE LAYERS OF GLASS TO THE INSIDE SIDE OF THE OUTER SHIN WALL THEN PLYWOOD OR COMPOSITE MATERIAL AND THEN GLASS FOR THE INSIDE WALL. FOR ME THOUGH I PROBABLY WOULD NOT DO IT THAT WAY IT SEEMS YOU ARE TRYING TO SAVE TIME PLUS YOU DO NOT WANT TO SPEND A LITTLE MORE MONEY ON BEER. I WOULD BUY MORE BEER AND THEN I WOULD CUT A CHECKER BOARD PATTERN EVERY 4 INCHES IN THE TRANSOM PLYWOOD FROM THE INSIDE WITH A SKILL SAW CUTTING THROUGH THE WOOD BUT NOT DEEP ENOUGH TO HIT THE GLASS ON THE OUTER WALL. THEN I WOULD USE A CHISEL IN ONE HAND AND A BUD LONG NECK IN THE OTHER. AFTER THE WOOD IS GONE YOU CAN GRIND ALL EXCESS EPOXY OFF AND THEN START FROM THERE. MY GUESS THIS IS A FOUR SIX PACK TYPE JOB.
FELLOW-SHIP [img]images/icons/grin.gif[/img]
