Thread: Wood Rot
Old 05-18-2003, 09:14 PM
Briguy Briguy is offline
Default Re: Wood Rot
Tapping on the hull with a rubber mallot is a good way to begin to determine if water intrusion is a concern. Also try to remove a screw from a transducer, or trim tab. If there is any sign of moisture you have a problem. You can either keep looking or use a soft trasom as a barganing tool.
Capt. Brian
