Old 06-18-2003, 05:27 PM
Default Re: Gas Fill / Tank Vent Ground
I HAVE A SEPARATE LITTLE TAB ON THE GAS TANK THAT I ATTACHED MY GREEN GROUND WIRE TO I ALSO ATTACHED A GREEN WIRE TO THE GAS FILL I THEN CONNECTED TO A SEPARATE WIRE BLOCK UNDER MY CENTER CONSOL AND THEN RAN A THICK GREEN WIRE FROM THAT TO MY BRASS THROUGH HULL SCOOP THAT FILLS MY LIVE WELL. IF YOU DO IT CORRECTLY YOU NEED A BOAT GROUND PLATE THAT COST’S ABOUT $50.00 AND HAVE EVERYTHING CONNECTED TO IT, BUT MOST GUYS ARE OK WITH THE SCOOP SINCE IT IS ALWAYS IN CONTACT WITH THE WATER OTHER GUYS USE THE MOTOR SINCE IT IS IN THE WATER AS WELL I LIKE THE BRASS OF THE SCOOP NOT THE ALUMINUM OF THE MOTOR ALL MY ELECTRONICS GREEN GROWN WIRES ARE CONNECTED TO THAT WIRE BLOCK AS WELL.
FELLOW-SHIP [img]images/icons/cool.gif[/img]
