Thread: Leak
Old 09-09-2003, 09:40 AM
jw jw is offline
Default Re: Leak
Nj,
Perko Makes a deck scupper with check valves inside of them. These fit pretty well with a minimum amount of work. I used 1" K copper pipe to route the scuppers to the transom and then a 1" thru hull. Connected the pipe to the scupper and thruhull with 1" hose and doubled clamped everything.
Have not put the rig in the water due to fishing season, hope to have her wet next spring. I can send some pics of the rebuild if you want.
JW
Soon to be covered in Fiberglass dust again.
www.bansheecharters.com
Wishn' I was Fishn"!!!!
