Re: LT'S-BIG BRACKET ???
LTDan,
I'd like to hear how you made a footrest, or better yet see some pictures. As for the bracket, make sure you have a compressor, it will be much faster drilling those 25+ holes. Also 2 tubes of 5200 should be good enough. Also use an air impact tool to tighten those bolts down. I used a forklift to hold the bracket in place, then placed tape all around the bracket and hit it with a level to make sure it is streigt, also have a good ruler and measure from the rubrail down to the bracket on both sides. Make sure it is within 1/8th inch or less and also make sure it is centered by measuring from the bracket to the sides of the boat. When you have it all ready, drill and bolt 2 holes near the top and bolt it down tight(dry, no 5200). After its tight, lay on top the bracket with a black permanant magic marker and mark out all the rest of the holes, remove the bracket, drill all holes( I used a 9/16th bit) then blob 5200 all over the rim and around every hole. Bolt the sucker on with the bolt heads on the inside of the transom. Someone will hold the nuts with a crescent wrench from the inside and the other assistant, while drinking a cold beer with impact those down about 70% tight. Also smear the bolts with 5200, use rubber gloves. Do all the bolts and when done, go back and clamp them down to the max. Take pictures at every step with a digital camera. Peel the tape off and if you did it right, a nice bead of 5200 will be left. Let me know what else you need.
Capt. Brian
