Re: makin rub rail fit again
Ha Tex
First attach the two ends with a few screws on both port and starboard side at the stern rapping the remainder of the rub rail Under the bow of your boat then you can lift up the rub rail and stretch it into place. You might need a crow bar in a few arrears to lift up and stretch at the same time. You can use a rag or a piece of wood to prevent damage to your hull while you are re setting the rub rail. I wish I knew this trick before I did mine.
FellowShip [img]images/icons/cool.gif[/img]
