Old 06-23-2003, 07:45 PM
Ed Ed is offline
Default Re: advice on suzuki outboard
Trevor-
That should be covered under your 6 year extended Suzuki/GE warranty. You'll most likely get a brandy new powerhead out of the deal. Let me know how you make out ( I have the same extended 6 year warranty and it expires in August 2004). I've heard from others that if one cylinder does go bad in a Suzuki it is always number 6.
Couple of quick questions for you. What oil were have you been running in the motor? Did you use ring free or some other decarbon solution? Is it mounted at the standard height? What kind of use does your motor see on a regular basis...trolling, cruising or hold on...we're flying???
Good luck-
Ed
