Re: BORED Straight Flush !
Colors ?? Shiny,Solid ,?This Platypus can be pulled slow ? 2.5 ? That maybe to slow,Our boats Drift faster than that.Mybe the angle on the head gives it action at slower speed.The inner tube is also at a angle.When I came out with this lure I cut the angle both ways up/down(which shows in the photo) The upper cut came out the winner.Dives from side to side then will surface & run like a "BIRD" then Dive again.The under cut did just the opposite. Keep My brain work'n for a lil bit here.I can make the "TAIL" longer & use Mylar for a inner skirt.
