Old 01-22-2004, 10:41 AM
Default Re: I have a little problem?!?
It sounds like from the info you have posted that the company did not tie in the transom in to the splash well with enough glass and that could cause the cracks on the 4 corners and the little flex when you are bouncing on the motors. If some support strips of glass are installed from the inside and re gel coat the cracks would be the best way to repair the damage. Personally I have always had concerns about the amount of weight and stress that is put on transoms by the weight of two and now 3 motors weighing 600 lbs a piece and rated at from 500 to 800 combined horse power. I’m no stress engineer but when you build a boat and use composet material that doesn’t weigh much with ¼ to 3/8” thick glass on both sides of the transom that will eventually collect some water and now the pressure of the boat going through 4-6 footers with the boat on occasion coming out to the water jumping over waves I get concerned about all 2 and 3 motor boats.
FellowShip
