Old 02-10-2004, 04:09 PM
Default Re: would this work?
Ha George
Personally I would have a real concern draining my boat out the sides close to the water line of the boat. If I was going to change mine I would go through the transom that way you can use a number of devices to prevent water from coming back into the boat. Another way would drain the water into the engine sump area then the water would go through the transom scuppers. You could use your same idea but just channel it in to the sump instead of drilling hole in the outer hull at the water line. Or you could use “THE VORTEX” would cost you just $1.00 and one six pack of beer to make them. They work great and will prevent the water from coming into you boat from the scuppers that go through the bottom of your boat. If you look back on the board you will find the thread called “THE VORTEX” and you can read all about it its under the general headings I think.
FellowShip [img]/images/graemlins/grin.gif[/img]
