Re: Tabman in Miami
The 120s are 10(span or width) x 12 vs 12(span)x12 on the standard tab. Just gives you some leeway in mounting
.. the 120s have wings or fins that help channel the water out the back of the tab to generate the lift
making the 10 span efficient . I would think there would be some water release or slip from the sides of a standard flat tab hence a larger tab is needed.
I know I spoke with Tabman a long time ago and mentioned either tab would work but the 120 would give some more flexibility in mounting given the shape of the varying angles of deadrise in these boats
Tom (Tabman)
Have you ever been able to compare the 120s to say the 12x12 tab
. Curious as to how the 120s compare to a standard 12x12 tab
more , less or equal to... as far as in efficiency
.I wish I could find that picture of my hull we used to illustrate all this !!!!
