Old 03-11-2004, 01:02 PM
JW-Tex JW-Tex is offline
Default Re: Destroyed 20', pieces available to good home.
If you do the bay boat option, weight is your enemy so I would remove existing floor and go with the lightest option avaialbe to replace. You might also consider adding a pocket tunnel to the back (I think Keener offers this on thier v hull bay boats) the tunnel will allow you to run the motor higher up and provide more clearance for the prop. I think you could probably put a 3 foot pocket tunnel in the back and increase your draft substantially.
JW-Tex
Moesly 1969 20 CC & Potter 1978 23 CC (23 in storage awaiting rebuild)
