Re: Please, I Need HELP or suggestions
Hey Jim, Sorry abut your luck.
Have you thought about renting a trailer and going to pick it up on that.
I know from moving your 20 around you pretty much know what you've got to do. What I've done many times is back the boat and damaged trailer up to somthing immovable like a telephone pole. Run a large rope thru the stern eyes aroud the pole and then slowly pull the damaged trlr out from under the boat while blocking up the boat as you go along. Then the same process in reverse with the repaired or rented trailer. Chances are that after the weights off the trailer it will be ok on 2 or 3 wheels to tow to repair or scrap yard. Just a thought.
