Old 03-22-2004, 08:18 PM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Fiberglass box seats - Tsunami/ Sceptre
I like the thru hull drain - was that a problem for you other than the boat leaning forward - I hope I do not have this problem - won't know until I put 'er in. I forget, why does your boat lean forward ?
Is that a common problem w/ Tsuanmi/Sceptres and why ?
Alan,
Sure, I can get you exact measurements, but right now the boat is shrinkwrapped and behind a locked gate that I don't have the key for. The thru-hull drain wasn't a problem per se, we just didn't like the idea of a thru-hull below the waterline that wasn't absolutely necessary. I believe the outboard Sceptres lean forward due to the additional weight of the deck and the 144 gal. fuel tank. With a single I/O, I know you won't have this problem. Jack from this site has an '85 I/O (260hp MerCruiser) and it sits correctly.
