Old 03-25-2004, 08:34 PM
thedink9 thedink9 is offline
Default Re: deck repair question
Fellowship
I was a bit surprised that your deck plywood meqasured 3/8 to 1/2 inch. I just took out all the core material out of my tank and livewell hatches and this material measured 5/8".
I have a CSY built 23' '85 and am about to start the deck rebuild. I'm wondering if the deck thickness is 5/8 or thinner, as you found in your boat. I assume you have a potter era hull! I'm going to reuse the top skin .
How far under the gunnel (past the point where the liner begins to turn up does the wood go? You indicated you filled this void with thickened epoxy. Didn't this mixture tend to run out?
Dink
