Re: The subject is a 74 20 cc with some problems
abl111,
How large of a hole do you need to drill (the oversize hole). Would you go 4" diameters if not using a core material such as divinycell like Bill used. Also, do the motor mounting washers on the inside of the transom need to be larger than the oversized hole you previously filled with cabosil and epoxy.
Thanks -Will
