Old 05-06-2004, 07:16 PM
jw jw is offline
Default Re: Re-Attach Deck to Stringers
I would use a thickend epoxy( cabosil and a rigid foam to fill in the low spots. Then i would use vey long drywall screws to pull everything together. Remove the screws when the epoxy is cured fill the holes and away you go on to annother part of the boat projedt.
JW
www.bansheecharters.com
Wishn' I was Fishn"!!!!
